Banging/clunk when accelerating from coasting or letting off gas (2015, 8 speed, LR4/Discovery 4)
Arman
For a long time I had intermittent issue of driveline kicking (as if a clutch was dropped when driving manual) when accelerating after coasting/rolling. The driveline would kick when pressing on gas pedal after a prolonged roll.
I am not sure on what is the cause of this problem. Transmission pan and fluids were changed and adaptations were reset. I guess transmission solenoids and maybe a valve body needs to be rebuilt?
Now, recently I started noticing a loud/heavy banging/thud when letting off a gas pedal.
I guess with enough kicks from the first problem, either the engine or transmission mounts could have worn out, leading to the second problem (thud when letting off gas). Engine mounts look like a pain to replace. I already noticed some cracks on the transmission mount (when doing pan and filters), so I think to start with that one. Anyone knows a difference between LR092039 and LR091364? I know that the LR092039 is what fits, but was wondering if the LR091364 (that is installed on 13-22 RR and 08-13 RRS) is somehow a higher quality part with a hydrobush instead of just rubber LR092039? They look very similar, and some aftermarket manufacturers even advertise their parts as replacement for both of these part numbers.
