speedometer/tachometer/tempeture gauges quit
dnamelton
Hi, i have a 98 Discovery LSE with 150k. It runs great, but has developed a wierd Rover problem. I can start and run the Disco just fine and all the electronics work, mirrors/windows/seats/ radio even the sunroofs work perfect. But all the gauges are dead, speedometer, tachometer, tempeture and fuel. All the idiot lights work. Is there a fuse under the dash thats not listed in the manual or a wire thats loose? Maybe a grounding issue? Any help woul be apreciated, thank you.:confused:
Pull the cover from the fuse section and read what fuses is what.
You either have a fuse blown or a cracked circuit board in the cluster.
dnamelton
I checked all the fuses, there fine. I guess it's time to pull the instrument cluster and look for cracks. Good times, thank you.
STQAddie91
