Sunroof
rchase
Last night there was a lot of snow on my roof and i didn't notice. I went to tilt my sunroof and could tell theat it was resisting due to freezing or weight. I instantly hit the close button to stop the process. This morning I went to open it and it will not open. Checked Fuse #20 in the passenger fuse box and it was perfect... Anybody know what might be the problem? Thanks
I don't know but try holding down the open button with the key in the II (I think) position for >20 seconds.
EIGHTLUG
Is it possible that it's froze shut? It was always a problem for me, when I lived in ALASKA. What are the temps like, where you're at?
roverman
Here in Michigan, 28 is still below freezing. :)
Do what Houm said, and if it starts moving, hold the button through the whole cycle to reset. If the sunroof seal has still got a good frozen hold on the glass, it won't work until it has thawed.
rchase
Wow I have been driving around all this time, no sunroof, and didn't even see your fix to the problem. Did what you said but i held close for 20+ after open didn't do the trick and it worked!! Thank you!!
Cummins
