SW Updates and TSB's for 2006 LR3
OCPaul
I recently bought a 2006 LR3 with 10K miles from a dealer, and it is CPO'd.
The tires were worn inside, and I got the dealer to replace the tires and recheck the alignment, under a Land Rover TSB.
I am a little concerned that the dealer might not have been too thorough in their CPO check - the tires were no where near the 75% they should have been.
Is there anything in particular I should have them check, or confirm that they have checked for my model year? Software or other TSB's in particular.
Thanks!
richpike
Alignment is a big one. The LR3 will eat tires if out of alignment (as will any 6000lb vehicle). Another big one is on the throttle tip in - when you are coming to a stop (like a red light) and it turns green right before you stop and you start to accelerate, sometimes the car will "clunk" in to gear. There is a SW bulletin out on this one.
There is also a problem with the sunroof drains clogging and allowing water in to the footwells.
Outside of that, most of the 2006s have these issues already taken care of. I'm betting you'll be fine - just stay on top of the alignment (and get some new tires outside of the Goodyears :biggrin:).
-Rich
Edit: I forgot the knocking in the steering column when going slowly over large bumps (it happened on mine pulling in to my driveway - we have those angled "curbs" at the base of our driveway for water control).
richpike
Here are all the TSBs for a 2006 LR3:
Make : LAND ROVER Model : LR3 Year : 2006
Manufacturer : LAND ROVER
Service Bulletin Number : 00097 Date of Bulletin : DEC 12, 2007
NHTSA Item Number : 10023993
Component : STEERING:COLUMN
Summary :
STEERING COLUMN KNOCK - REPAIR PROCEDURE. *NJ
Service Bulletin Number : 00084 Date of Bulletin : OCT 05, 2007
NHTSA Item Number : 10023944
Component : VISIBILITY:SUN ROOF ASSEMBLY
Summary :
GLASS ROOF PANEL BLIND DIFFICULT TO LATCH - REPAIR PROCEDURE. *NJ
Service Bulletin Number : 00054 Date of Bulletin : MAY 25, 2007
NHTSA Item Number : 10021975
Component : EXTERIOR LIGHTING:HEADLIGHTS
Summary :
HEADLIGHT CONDENSATION. *KB
Service Bulletin Number : 00013 Date of Bulletin : MAY 24, 2007
NHTSA Item Number : 10021974
Component : ENGINE AND ENGINE COOLING:ENGINE
Summary :
SLOW ACCELERATION FROM A STANDING START. *KB
Service Bulletin Number : 034 Date of Bulletin : NOV 27, 2006
NHTSA Item Number : 10020748
Component : OTHER
Summary :
VEHICLE ENHANCEMENT PROGRAM. *KB
Service Bulletin Number : 051 Date of Bulletin : OCT 27, 2006
NHTSA Item Number : 10020712
Summary :
CHANGE REAR DIFFERENTIAL OIL QUARANTINE. *KB
Service Bulletin Number : 501012 Date of Bulletin : MAR 14, 2006
NHTSA Item Number : 10018823
Component : STRUCTURE:BODY
Summary :
POSSIBLE CAUSES AND RESOLUTION OF WATER INGRESS - PASSENGER COMPARTMENT. LANDROVER LR3. MODEL YEAR UNKNOWN. *TT
Service Bulletin Number : 308001 Date of Bulletin : MAR 14, 2006
NHTSA Item Number : 10019770
Component : ELECTRICAL SYSTEM: INSTRUMENT PANEL
Summary :
INTERMITTENT TRANSMISSION WARNING LAMPS OR MESSAGE. *TT
Service Bulletin Number : 501016 Date of Bulletin : MAR 14, 2006
NHTSA Item Number : 10019761
Component : STRUCTURE:BODY:TAILGATE
Summary :
TAILGATE SUPPORT MOUNTING. RATTLE FROM THE UPPER TAILGATE AREA. *TT
Service Bulletin Number : TA204001 Date of Bulletin : NOV 05, 2004
NHTSA Item Number : 10011807
Component : SUSPENSION:REAR:SPRINGS:AIR SUSPENSION SYSTEM
Summary :
INTERPRETING AIR SUSPENSION MESSAGES IN THE LAND ROVER LR3, AN THE LA MODEL. *TC
OCPaul
Thanks Rich! I seem good on everything else for now, except perhaps the throttle tip-in. It can be very jumpy at slow speeds.
Do you know if there are software upgrades also?
I have the bluetooth option, and it will not pull the phone book on iPhones. Another LR3 owner has told me there is an update for the software to address this.
Do you know if LR update the car's software as part of the maintenance schedule?
Cpa4S
Summary :
Summary :
Summary :
Summary :
Component : OTHER
Summary :
Summary :
Summary :
Summary :
Summary :
Summary :
great list rich - thanks.
btw - i haven't had an issue with any of those points with our LR3.
richpike
The throttle tip in is a SW upgrade. Not sure about others.
It is probably dealer specific. We have an awesome dealer, but they typically don't do the SW updates without being asked, or if there is a problem. It is sort of the old saying "if it ain't broke" - if the customer isn't complaining, don't mess with a good thing :biggrin:
-Rich
richpike
That's awesome - I actually feel like the LR3 is fairly reliable (at least compared to most European cars which are always a little quirky). It just took them a bit to work out all the issues - by the 2006 model year I think they were getting pretty close to being good. And the 2005s are good too, assuming you've had most of the TSBs and updates done.
-Rich
OCPaul
RIch - that's exactly what the service guy said to the sales person when I questioned the alignment problem a day after picking up my LR3.
When I mentioned the TSB specifically, and asked if they had addressed it when they certified the vehicle he shrugged and said "we only do it if the customer complains".
Not exactly the best approach to managing Land Rover's reliability reputation, but I guess as long as you know what to ask for it's all OK.
Thanks again for helping us all understand what to ask for. I'll ask them to take a look at any available SW updates next time I go in.
PanKyiv
