Tire pressure monitoring - changing tires
A
agavrilo
I just bought 2006 Range Rover, which came with two sets of wheels. I am about to change from the summer wheels (22inch) to the standard 19" Range Rover. Since I have no idea how tire pressure-monitoring works I am concerned the tire pressure monitoring system will not work properly once I swap the wheels. What if anything do I need to do to make it work? Thank you.
Not sure on the new RR's, (I would call the LR service guy to confirm) I do know on most monitoring systems it can only monitor one set of tires at a time and either the equipment will need to be moved from one set to the other or you need to reregister the new set.
Bet it will cost money if the dealer has to reregister.
M
Mouse
I put different tires on and the light just stays on all the time.
PE_in_UAE
