Turn Signal Problem
P
porschedoc
2000 Landrover. Recently the turn signals went haywire. If you turn on the right turn signal, all is fine. If you turn on the left turn signal, both left and right turn signals flash, as well as the middle brake light. I have replaced all the bulbs on each side, and still the same thing. Any ideas?
Karl
Sounds like a bad Switch... normally you have problems with the headlights. Could also be a bad wiring connection to the switch.
J
john65b
Could also be a short - look at all the left hand bulbs sockets to see if you have a short...
Rover head
I am having a similar issue RR P38 2000 the left urnig signal works just fine but the right one doesn't, although it turn on the hazard lights both sides blink just fine, is it the switch ? or could it be a short?
Thanks
