Vss?
LRWheelman
Hello, All! Where does one go to locate the "Vehicle Speed sensor" on their 96 Discovery? I'm suspecting problems w/ this item and would like to check the contacts, values, or if it is even still there! I am thankful for any help on this issue.......Thank You, LRW. :hello:
Monty
Here's a link to d-web's tech. http://discoweb.org/ Check the tech section and look up vss. The author didn't state if the replacement was for a I or II but it might give you some insight. Good luck!
LRWheelman
thank you Monty very much, it is very greatly appreciated
thank you...LRWheelman :biggrin:
