Washer Fluid Low Warning
Cruiser
2011 LR4 HSE - Anyone else have a persistent "Low washer fluid" warning on an LR4?
I've filled it to overflowing twice, and still won't clear. Not leaking at all anywhere.
iconoclast
In, Out & Around...
Have you been using Rain-X or similar product? If so there may be build-up on the sensor causing the fault. If not the sensor itself may have failed on it's own.
PE_in_UAE
