Water in Floor Board
jtb
2004 Disco-getting water in floor board while AC is running. Water is very hot. Any help would be appreciated.
jmrivera
I must be reading and understanding your issue incorrectly...
You have very hot water that soaks the front interior floor (under the carpet) when the A/C is operating??? Both sides?
Sounds either like the A/C drains are clogged or you have a bad heater core, if it smells like antifreeze, then heater core, of not... drains.
jmrivera
Hey Joey,
How do you unclog the A/C drains?
My '03 is dripping cold water from the fan blower and I am assuming this is the issue...
Thanks,
Jonathan
If you crawl under the disco right about the front of the driver door (basically just behind the front tires) you should see (one on each side) a plastic tube coming down on the side of the transmission and it will have a small ****** on them... easy way is to either stick something in the ****** or just pull it off. Keep in mind if it is clogged you will get a face full of nasty water.
PE_in_UAE
