wet floor
discomk
2004 DISCO HSE7 60K
:confused: front passenger side gets wet when the A/C is on. no drip from the top or side, what is under the carpet? :confused:
Sounds like your A/C drain tubes are clogged.
discomk
how to check and unclog the A/C drain tubes, please?
discomk
per DISCOMIKE's phone call. found the end of the drain lines. wiggle the ******* and a bunch of water drained out from both sides.... thank you all. special thanks to mike. you are the man!!!
PE_in_UAE
