When it rains, it pours
D
discomike
A small , RED, I believe, box should be under the pass seat and you should see code numbers on its surface.
Mike J.
D
discoskc
The only red box I saw under the passenger's seat was the box for the Service Engine light... the emissions control reminder box. This was next to the amplifier under the passenger seat.
D
discomike
Since I don't have an D1, I am going at this from what others have said which was the code display is under the pass seat and the servive reminder light is in the r/f pass kick panel.
I don't know what to say .
Mike J.
D
discoskc
I found the box under the passenger seat. Its a black box with clear display on the front towards the rear seat.
No codes on display. I turned the vehicle on and the box under the passenger seat is blank. It turns on to 00 or 88, but that display goes off immediately. Other than that start-up charge on the LED, nothing else is on.
Is there some other way that I should be looking at codes?
D
discomike
Sounds like it is time to get it to a shop, have them plug in and see what show up while running.
Let us know how it goes.
Mike J.
D
discoskc
Should I take it to the dealer? Or any independent shop should be able to help me with this? Do they need to have the AutoLogic computer to diagnose this?
D
discomike
Either way works, the independent would probably be cheaper and yes you nee AutoLogic, do you know of such a shop, if not here is their 1-800-533-2210 number call them for a shop name.
Good luck,
Mike J.
STQAddie91
