Who says Rovers leak oil??
J
J-Trana
I don't know if mine is a oil leak or what... I have this black oily dust on my front tire rims and it gets thicker each time I drive it. I have only had my 2001 D II for about two weeks now so I am brand new to everything that can got on with my Landy
Any help on what it might be...
D
discomike
Sounds like what you are describing is brake dust, commom on any heavy vehicle, especially if they have cheap aftermarket brake pads.
Mike J.
RoverChic
I love Ryan and Rovers
If it is oily..Make sure that you are full on Brake Fluid too. I had brake dust that was oily and my piston seals had busted on the driver side. Just an FYI. Good Luck.
J
J-Trana
Just dust
Thank goodness... I took it in to day and had it checked out, Takeo had e-mail me with some information too... plus the cheap brake thing. So when I went in there I was ready with question of what I thought it might be, and I also mention that I had received information from a member of a Landy club... he reasured me that the brake were not cheap one they are blah, blah blah... (can you tell I don't remember... lol)
I want to thank you all for answering my question and I am sure as time goes on I will have a lot more too.
thank you, Jeni
Militant-Grunt
Land rover of manhattan says that the engine in my disco has minor oil leaks, and that the engine needs a reseal.. but it would cost like 2 grand to do so its not worth it..
F
faisal_in_laurel
Hmm.....may be because mine has a lot of miles (175K) my oil pan leaked for gaskets. Replaced the gaskets and the leak on mine stopped.
V
vaporhat
I have 76K on my 99" D1 and I have a few leaks myself. Nothing that leave a mark on the ground but I can clearly see some seepage. I just keep an eye on my oil level and don't stress it.
Sam Grant
My 2000 D2 I recently bought doesnt leak a drop, -fingers shall remained crossed though!!-
T
tcosson
It's probably out.... lets see if your still bragging after the thing siezes up ;)
Sam Grant
I checked it two days ago, amazingly it was full! Although the Porsche is leaking enough for both of them :)
Hae79547
