Will not start !
P
paul
99 Series 1 with 80,000 miles, well maintained. No power to fuel pump. Tried the lock/unlock 4 times, the fuel pump reset button, checked the fuse and no loose wires. Too many tricks on these trucks - what next?
Moose
Inertia switch will cut off fuel pump, maybe it needs to be reset/replaced. Look on the passenger (US) firewall, there's a plunger-looking switch with a rubber top. Push down on it, if it clicks you've reset it.
Any other ideas, folks?
P
paul
Thanks - tried it along with the relays - still no power to the fuel pump.
There is a fuel pump relay on the passenger side footwell, but if you hear it click (very quiet, have someone turn the key an listen) if that isn't it. You also have a connection on the drivers side frame right next to the rear tire, that can cause issues.
BCNJ
