Trunk Latch Issue
05LR3MA
I have an '05 LR3. The other day I tried to open the trunk but nothing happened. I could hear the electronic mechanism but the trunk still wouldn't open. Has anyone run into this before? Any suggestions?
Thanks for any feedback!
trm2
Search this forum. Happens every 2.5 years. Silly design inside the tailgate. I just have the dealership break into the truck and open up the tailgate and replace the failed part. It is a pain when the trunk is full up with stuff. And, replacement is not free. Others on this forum have suggested improved solutions, but my dealership refuses to implement them.
05LR3MA
Thanks for the feedback! Do you think it would be covered under the LR certification program? What have they charged you in the past to fix?
trm2
I'll see if I can dig out the most recent receipt tomorrow. The first one I believe was covered by the original LR warranty.
trm2
Parts = $235
Plus labor.
I can't figure out the labor because multiple items were repaired. Maybe $150.
buybrakes
LR Tail gate cable defect
Happens to many according to the research I've done. Should be a class action on this one. There is no fail-safe if the cable breaks, so the only way to get in to the rear hatch is to have a dealer force the inside rear panel pieces off and then replace cable or reattach. Cost me just under $300 and it happened one money past my warranty expiration.
Hock
Read this post, I followed this and fixed myself. http://www.landroverworld.org/forums/showthread.php?t=19249 which include the technical bulletin . If under warranty get them to do it, because it is not fun. 9/10 times I think they can fix without replacing parts - should be about $200. Any decent mechanic can open the top gate without ruining the carpet panel, IMHO - but a lot of shops will take the easy route and cut your carpet panel, then replace it.
tflint2112
