Trailer wiring harness
Agarabaghi
I got the wiring harness and hitch adapter for my LR4... I saw a video from AB on youtube on how to wire it in, looks pretty straight forward...
Anything I am missing?
brettmess24
It's that easy.
If you want the stability control and tow assist if you have the 5 camera system you need the dealer to activate or purchase the IIDTool.
The lights for your trailer will work without the activation for tow assist and stability assist.
Enjoy
eljefe
i bought mine from Atlantic British and used the video as well. It is that easy.
bash535i
It's that easy.
Enjoy
I thought the stability control was always on. It seems that a safety feature would always be activated by default. Can you give further info on this?
brettmess24
No it has to be activated by the dealer or wait for the IIdtool.
If you don't have the tow harness you do not plan to tow so it is not Active. Check the picture of a computer for the last step on the instulation instructions. There are settings that need to be turned on.
Agarabaghi
Ok, will the dealer do it free of charge?
Also how much is the IIDtool?
brettmess24
I doubt the dealer will update for free. If they are nice they most likely will charge you half an hour if not so nice a full hour. It really is only 10 minutes to make the adjustments with the IIDtool.
Do you have the 5 camera option?
IIDtool has two options regular and bluetooth version. Not sure on price ask AB or email gap diagnostics.
Agarabaghi
I do not have the 5 camera option. So i guess the only thing would be the stability control?
brettmess24
Yes that is correct. Depending on what you plan to tow you may not care or need the stability assist.
I tow a 6000 lb boat.
Agarabaghi
Boat - 3200lbs dry, trailer 1200lbs, there maybe 500+ lbs of stereo and gear on the boat... and thats assuming we remove the 600lbs of lead hidden under the seats...
