Just picked up EBC pads and rotors
Izzyandsue
Changed my brake pads for second time on the LR4, 34K miles. Rotors are only halfway through their life, fronts at 28.7+mm for example. My wife drives the car all day around town, stopping and going traffic. I am surprised others have had to replace rotors already. When removing the brake sensors, be careful you don't loose or throw away the sensor clip that can get stuck on the pads.
I always follow Bodsy's bible for Disco3 brakes, A few photos to help with some differences to the LR4. The first one is critical for any LR4 owner removing wheels, I extend my 18 breaker bar with a 30 black pipe, makes the dealer over torqued nuts come off easier and cost $7 at hardware store.
By the way, the wooden tool I use to hold rear caliper up and to help push in the pistons is for sale if anyone is interested.
TXLR4
Thanks for posting Izzy. Have you gotten the rotors turned at all when you replaced the pads?
Izzyandsue
Nope, no turning rotors unless they are warped. I only had one time on an old honda minivan that had actual warped rotors. So I just replace pads and bed them in. This may incite tremors for the purists out there, but that's what I have been doing on my cars for 30 years.
The factory Land Rover rotors are made of soft and fairly thin metal, they are easily damaged if you try turning them. That's why virtually all dealers and most knowledgeable indies won't even try that.
Izzyandsue
That's good to hear. When my rotors are done I will see if I can take them to the lab for a Rockwell test on the steel, bring some of my racing gears and compare/measure how softer they are relative to Brembos or Stoptechs.
cypress822
What happens if rear brakes are done, but the parking brake is not adjusted/recalibrated?
stmcknig
If you mean the parking brake shoes inside the drum rather than just the rear pads, failing to perform the adjustment will result in some god awful screeching from the EPB module when applying the EPB and if ignored most likely a replacement module at a cost of $700...
cypress822
Would a independent brake shop know to do this, and do it correctly?
RBA
Is there a thread on this somewhere?
