I need recommendations on ignition coil for a 05 lr3 v8
Gabe
Illinois
I recently bought some from Amazon and they worked great for about 2 months. Now I'm back to square one with a bunch of misfiring in the engine. According to the scanner it point out the ignition coil #7 #5 are the problem. I've moved both around only to generate more engine codes. What brand would you guy's recommend on purchasing? Any help would be great.
Thank you
Sent from my SM-G955U using Tapatalk
Gabe
Illinois
Thank you
So I finally got around to changing the spark plugs, coils and the problem continues. I clean the mass air flow sensor and the truck is running great again.
PE_in_UAE
