LR4 problem with trailer brake/turn light
Lgibson
SorryI don’t know what the adapter will do for you. Perhaps the uhaul place will let you try one with return privilege
jackkyxu
thanks
actually I want to ask how you are sure about the 100 ohm resistor to make the trailer light working
any data point on this 100 ohm stuff you have ever heard about on LR4?
Thanks
Lgibson
thanks
Thanks
No, 100 ohms is just what the adapters contain.
Trust me, you will not see the trailer icon on your LR4 instrument panel until the module sees a current draw of 14.4 watts. If you plug 14.4 watts current and 12 volts into a calculator you will see 10 ohms is the required resistance for that 14.4 watt draw.
jackkyxu
I got this 10 ohm / 14.4 watts
I just want to know whether the etrailer adapter with 100 ohm will get the trailer light on or not
I need a temporary solution now since I am moving the coming Sunday
thanks
jackkyxu
update:
etrailer adapter with 100 ohm does not work with LR4
here is the solution
it is easy to open the etrailer 7pin-4/5pin adapte, just 4 screws
after you open it, you can see there are 3 resistors soldered in parallel between the negative contact (from white wire) and signal contacts (from brown, yellow, green, blue wire)
just need to change the resistors from 100 ohm to 10 ohm
question where to buy 10 ohm, 20w resistor with relatively small size
BCNJ
