Rear strut
mattmann
Arkansas
Quick question for you more experienced owners. I bought a lr3 about a week ago and immediately noticed a lot of squeaking from the rear passenger area. Between myself and my father in law, we have both decided fairly certainly it’s the strut assembly and not a bushing. I ordered a used oem one from eBay that is a pull off in decent shape for $90. This is not a every day vehicle but more of a hobby truck for me and my family. Anyways, the install seems fairly simple but do I need to drain all the air from the strut? I have the truck in “access mode” to fit in my garage, is that okay to change it while it’s in that mode or does more air need to come out? If so, how do I accomplish this? Thanks in advance!!
mattmann
Arkansas
Is this a dead forum??? I feel like I would have at least one response??
COBlue
First, nice looking rig!
You’re putting the truck on jack stands right? You’ll want it as high as you can get it so you have room to work.
At the top of the strut are three nuts and the air line. You have to detach the line at the strut which releases the pressure from the air spring. Then you are only working against the resistance of the shock.
I dropped the spare to get better access to the nuts and air line.
It’s not a difficult job, just time consuming because of limited wrench swing. A ratcheting flex boxend or 1/4” drive socket really helps.
mattmann
Arkansas
Thank you so much for the comments. Little tricks like dropping the spare is helpful for sure. I wasn’t using a jack stand but do I need to?
Redinak
So the squeak was from outside? My tailgate squeaked for a while until I fixed it..lol
morrisdl
YES - Jack stands. 3 ton trucks falling on you is very unhealthy.
IMHO - Squeaky struts is rare. More likely a bushing in the control arm.
mattmann
Arkansas
Ended up being the lower control arm bushings.
