Water pump. FAIL
You owned a P38?
I guess the real question is: would you ever own another?
scott schmerge
Charlotte, NC
You owned a P38?
I would. Great truck. I do all my own work though, so it never bothered me much to tinker. Surprisingly I had very few issues with it. I had it from 35k to about 165k. Issues with heater core, suspension, and ignition system, but that’s about it. Otherwise ran flawlessly
Erik Green
Seattle
Ok so all reassembled, all good, except I screwed up and put in the wrong coolant, maybe 4 quarts worth, didn’t realize the little sticker till it was too late. So do I need to do an entire coolant flush? What are the options here? (Never realized the organic acid specific to lr)
scott schmerge
Charlotte, NC
Depends on what you put in. Mind sharing?
Erik Green
Seattle
Nope so first I got the valvoline max life for all makes and models (red). Then about a bottle of peak 50/50 for all makes and models (green).
Just took for. 2 minute drive and it said overheating and switched to slug mode
One more side note after driving the coolant reservoir went from cold fill line when cold to completely full after warming up and driving
Erik Green
Seattle
Ok so right now I capped the line in red, but now that I know what it’s for and the stock way was the lines In green and I need to redo the red to the green . Not sure but I’m guessing that’s what’s causing the overheating issue? Can’t be coolant, not that fast
scott schmerge
Charlotte, NC
Air lock. Use proper bleed procedure
DoornbosH
