Replacing the accessory drive belt?
Califly
Southern California
I've looked up and down the interwebs, but I can't find a video or step-by-step instructions on replacing the accessory drive belt (LR012663) for my 2011 LR4 HSE V8. I can change the serpentine belt without issues. Can anyone help?
Michael Gain
Clarksville, TN
If it were longer, I would say that you could feed it over the fan and be alright. Based on its length though, you should probably remove the fan clutch.
Califly
Southern California
The fan is off, but the belt is super tight. I don't see any tensioner (like the one for the serpentine belt). Should there be enough stretch in the belt itself to install without a tensioner?
It's a stretch belt, no tensioner. You should use a new belt each time you remove it. Land Rover probably has a fancy tool but in essence you just pry it on there.
Califly
Southern California
I guess there is a special tool (303-1500) to install the belt, but it costs $200+? Is that right??
Any tricks to install the belt without the tool?
blake aiken
denver co
I picked up one of these from autozone or something
wardheyel
You will need the tool mentioned above, but it will take some patience. Try to get the old belt off with the tool, don't cut it. It gives you some practice on how it works. In my case, I got the old belt off, but when I tried to put the new belt on, it ended up shredding it. It was not lined up properly. I was then able to put the old belt back on until I could get another replacement.
Justin Mann
Columbus, Ohio
This took me a ridiculously long time when I did it. Ended up buying the tool directly from Bosch. Ruined more than a couple belts. The key for me was the tool and an extra person. I had the extra person rotate the belt with a socket wrench and I was on the left side when facing the front of the vehicle guiding and stretching the belt on. I also feel like some belts have a bit more give as I tried a couple manufacturers. If I can find the spare I bought from Rock Auto I'll let you know which one ended up easiest for me.
N Markley
There's a video on YouTube that shows how to install a tension belt using a pair of vice grips on the crankshaft pulley. I followed the method and it worked very easily and without needing to purchase extra tools just for one job!
You basically install the belt on the smaller pulley first and get it started on the crankshaft pulley as much as possible. Tightly place your vice grips on the outer crankshaft pulley lip (front of vehicle) right where the belt begins to come off the crankshaft pulley. Use a breaker bar to slowly spin the crankshaft and the vice grips will force the belt onto the pulley as it turns. No special tools required and works like a charm! A little patience will get you there.
My Battlecat
