Adding Adaptive Cruise to LR4
taylo951
Austin
Has anyone done this? I think you can source the parts abs just activate via GAP tool? Any first-hand experiences?
I think on disco3.co.uk there have been some guys that have tried to do it. I don't recall if they were successful.
I think if your Disco is a 2014+ then it's relatively easy because the wiring harness is there, and you need to source the hardware and then just add it via the GAP tool.
2013 and lower do not have the wiring harness as far as I'm aware.
Nechaken
I talked to GAP about this. Looks like it only works on 2015 and 2016. Not all of the 2014s have the harness and supposedly the code for the adaptive cruise isn't in the ECU. Sounds weird to me, since the ECU has the same part number as the later ones, but they're the experts. They also said you can't put a 2015+ ecu in a 2014 car without changing other modules, and you can't flash 2015+ software to a 2014 ecu.
Stuart Barnes
Los Angeles
They’ve thoroughly beaten this subject to death. Also lots of pics of precisely what’s needed and info on the steering wheel mods for the additional control etc.
Good luck.
16FujiDisco
Nashville, TN
Pretty certain it was an add on. Took me many months to find an LR4 with ACC and HD package when I bought mine a few years back.
tflint2112
