2011 LR4 HSE overheating
The codes should be saved in the ECU even if the CEL doesn't remain on, though.
To be clear, you're checking for codes with an OBD scanner, right?
MasonLR4
Georgia
To be honest man. I haven’t even check any codes. Haven’t had time to mess with it much, just starting to dig into this issue. I’m going to drain the oil tonight and see if it’s milky. If it is I’m going to start the process of new head gaskets. Would a coolant pressure checker leak down due to a head gasket?
Head gaskets failing on these are rare (unless the vehicle was overheated)
The most common overheating issue is due to the crossovers cracking. There's a lot of threads about the crossover pipes.
I believe the water pumps can leak a bit as well, and I had a hairline crack in my radiator recently.
New waterpump/crossover pipes should fix most problems, the only concerning issue you posted is that your disco failed the block test.
MasonLR4
Georgia
Thank you. I have a coolant pressure checker on it now. To make sure I don’t have a coolant leak also. I’m going to check the oil tonight for the final test to verify the head gasket.
A562NV
