brake pad sensor light
Kerrie
Troy, Mt
I recently replaced the brakes, front and rear, along with the pad sensors. Now I'm getting the brake pad worn light. Is there an easy reset or do I need to buy new sensors again? I bought a kit from FPC. (2013 lr4).
Also, can anyone recommend a good mechanic in the northwest Montana area? Kalispell and Coeur d'Alene are both 2.5 hours, so those would be the closest big towns.
There's no reset for the light, it just comes on when it senses the pads are worn. My guess is the sensor either came loose and got prematurely worn, or is somehow getting continuity through faulty wiring or something similar.
Rover Range
Texas
More than likely, the sensor is not plugged all the way in.
There's a wire inside the sensor, when it wears through the light turns on.
Kerrie
Troy, Mt
Ok. Thank you. I'll just buy new sensors then. I watched a video where a guy stuck a paper clip in the wire from the car to kind of short it out. I'm afraid to do that! lol. I'd be worried that I'd damage the wire, in the car, permanently!
HarryO
Had my break warning light come on after getting my wheels balanced- turned out the little wire that runs down to the sensor was rubbing against the wheel and had worn through the wires.
Izanagi
