Help needed!! More head scratching on battery/alternator/charging system... '06 LR3
steveC101
Hey guys,
I’ve read through pretty much every forum thread known to man in an attempt to fix what I thought was a pretty simple problem that now has taken me from scratching my head to banging it against the wall. I’ll try to keep this concise.
Three weeks ago while setting off from a traffic light my 2006 V8 LR3 battery warning light came on and was accompanied by a screaming from the engine compartment that turned out to be the cooling fan going overworking. The afternoon had been particularly hot (S Cal) and I’d been running the AC for the first time in months. I’d also had an occasion where the radio had stopped working. In March my Diehard battery had given up after 7 years of loyal service and I replaced it with a well reviewed and well priced Exide H8 from Home Depot. Limping the car home with the fan screaming with any acceleration I noted that on deceleration it would calm down and the battery warning light would go out.
Once home I charged the battery and ran tests on that and the alternator. It was clear that I needed to replace the alternator (at 128k miles). I ordered a reman from Autozone and after fitting it the light went out and the car returned to normal. For two days…. When I tested the old - original - alternator a diode test showed they had failed completely so that was clearly a problem. The grounds from the battery and alternator appear to be good.
Since then the car has been undriveable and at the last attempt while taking it to Autozone for testing the instrument panel went dead and the car was throwing transmission and suspension codes. However, other than that there have been no codes showing for the battery or alternator.
I removed the alternator and took it to Autozone where the output regulator tested as outputting 14.5 volts though when on the car it tests at 13.90 when running. This is at both the alternator and battery. While off the car I’d tested the diodes, which were reading around 400, which is below the recommended 500 to 800 zone. The shop manager replaced the alternator but when I returned home the replacement was also reading lower than recommended.
Thinking this was an issue involving the regulator I replaced the rear connector but that has also failed to rectify the issues. Here’s a list of what is still happening:
1. When starting the car the battery light comes on after 6 seconds and revs increase.
2. The engine idles at around 1200 rpm
3. When testing charging voltage the meter very briefly shows 14.5 V but immediately drops back to 13.9/92
4. I’ve had to replace the 5a fuse three times since yesterday.
5. On a few occasions when I’ve started the car the exhaust has been kicking out significant smoke, though it doesn’t smell like oil burning. The car is low on fuel and perhaps related to that but then it goes away shortly after.
Before throwing any more money and time at the problem I thought I’d pick the brains one here to see if there’s something I haven’t read or thought of. Thanks in advance.
Steve
remember5
I know this may sound redundant but honestly I swear by factory Landrover parts. However I replaced mine with a Denso from a local auto parts new, not rebuilt. There are so many systems on these things that inter-relate and work together that a failure in one system and affect multiple other systems. My only experience with a failed alternator was every light on the dash coming on and literally dying when I was pulling into the driveway. After replacing the alternator all was good. Attached is the only gen related section of the manual I could find. Hope it helps.
  • Description adn Operation.pdf
steveC101
Thanks for that. Nothing is redundant right now:) I just bought a remanufactured Denso and I’ll be taking it into the local Indy shop this evening. The way the car has been behaving I’m thinking it needs a deeper diagnosis than I can manage. I’ll keep this thread updated when I find out more.
steveC101
Things have only gone from bad to worse.... Took it to a second indy shop where a short was found between the rear connector and the ECU. However, the car then began overcharging - close to 18 volts and pretty much everything just lit up, except when the dashboard simply closed down altogether. It also has the engine light on along with a transmission warning (limited gears), park brake, suspension, you name it....
Thinking the internal regulator was shot I replaced the alternator with a remanufactured Denso but that was behaving the same. I took it in for testing and the regulator was shown to be just fine. I later saw that the battery voltage was dropping down to 12.2 about an hour from having been recharged. So I replaced the battery - again - charged it overnight and tried again this morning. Unfortunately as soon as I started it up this morning I'm having all the same problems.
Any ideas out there?
txfromwi
The system can put out high voltages if the battery cables and all connections are not tight.
Check all connections and make sure all the grounds are good.
From the manual for the 2013:
"NOTE: Under no circumstances should the battery be disconnected with the engine running because under
these conditions the alternator can give a very high output voltage. This high transient voltage will damage the
electronic components in the vehicle. Loose or incomplete battery connections may also cause high transient
voltage."
It seems that 16V is OK.
Again from the manual for a 2013:
"Do not rely on the generator to restore a discharged battery. For a generator to recharge a battery, it would take
in excess of eight hours continuous driving with no additional loads placed on the battery.
Trickle charging (defined as voltages <16 volts) may be carried out with the battery connected. Make sure that
the battery terminals are fully tightened prior to trickle charging."
I agree, way too many finicky systems on these to use anything other than Rover parts. It's just not worth it...
CJZA
GA
It sounds like there is definitely a loose connection somewhere in your system. The voltage regulator on the alternator is set to somewhere around 14V (probably 14.4/14.5V) and that is further regulated by the ECU. It is not abnormal to see 14.5V at the alternator during startup, but this is only for around 30s to replenish the charge used to start the vehicle.
You didn't mention which battery you have, but AGM will start swelling around 16V, so if you spiked at 18V you most likely fried the battery.
Best practice - Replace alternator with new (most guys recommend OEM Denso which can be had for around $250 to $300). Replace serpentine belt and tensioner whilst you are in there (not unheard of to have a failing tensioner causing the alternator to fail). Check all ground and battery connections - don't assume - loosen, inspect for corrosion and re-tighten. Fully charge new battery before installing (preferably with a charger that has a charge profile for the battery type). It is not unheard of to buy a battery that has been sitting on a shelf and is discharged.
Last resort - Test alternator charging voltage and do a parasitic load test. Alternator charging voltage will vary depending on the load and also what the ECU is telling the alternator to do. This will change depending on the temperature, load on the system, load on the engine etc.
Do you have a Gap Tool? If not, get one so you can monitor and clear the fault codes.
John Ricco
Boston
I have the same problem with my 07 LR3. Did you ever rectify your issue and if so how? I have been trying to figure this out for over 6 mths. I have replaced alternator twice ( both Denso including PIG connector), battery, starter and wire, fan and fan clutch, brake switch, Clusterfix, new cloned ECM and TCCM, battery, all grounds cleaned, relays and fuses checked, etc.
Making zero headway...Car starts and runs, then after 10 minutes, voltage spike to 17v, dash goes off followed by radio and A/C going off, car stuck in 1 gear....Shut down car and restart resets for about 2 min then the same recurs. No water intrusion, car garaged entire life. Problem also seems to occur sooner after starting when its hot outside.
Code reader shows multiple (at least 20) codes when this occurs, then codes disappear at restart
Dealer originally said alternator...they were wrong. Another LR mechanic said Cluster or ECM...both have proven to be incorrect and a waste of money replacing.
Help.....
itsaguything
Manotick, On, Canada
But out of interest... does the LR3 "qualify" for and AGM battery? AGM's require a different charging pattern than a flooded battery; and I thought that this particular generator/recifier solution was better geared for a flooded battery.
CJZA
GA
Help.....
Did you replace the alternator with new or reconditioned units? Checked all your ground connections? Even if your vehicle lived its entire life inside, doesn't mean that you didn't get some water inside the cabin at some point. All the symptoms you describe sound like an electrical issue somewhere. Either a corroded connection, or something that has worked itself loose enough to be intermittent but not loose enough to easily find and diagnose.
CJZA
GA
Correct, it does. The LR3 Bulk charge voltage (as dictated by the ECU/Alternator) never fully recharges AGM. This could be fixed by either fitting FLA or by putting the AGM on a trickle charger every so often. Land Rover changed the battery spec in 2013/14 when Stop Start was added. I found it hard to find an FLA battery, and when I did, it was only $20 less than AGM and the AGM had a 4 year warrantee.
