Smoke test, P0170 code and PCV
greiswig
SW Washington
TL;DR - should the PCV valve be sealed tight enough that a smoke test won’t leak through it?
Long version:
Now that I think I found the issue with the misfires on my 2016 SCV6, I wanted to see if I could find what might be registering in my GAP tool as a P0170 code, fuel trim on bank 1. This code only seems to crop up on long trips, and at the tail end of my last long trip, I could clear it and have it come back immediately. Here’s a 30-second log of what was happening there, for whatever help it is:
Thinking it might be a vacuum leak, I got a smoke test kit, and managed to rubber band around one side of the air intakes to seal it, putting the smoke input on the other side.
First think I noticed was that there was a bit of smoke where the plastic plenum joins the intake manifold. I remember having a hard time reinstalling that when I did my coolant lines, but I thought I had the clamp sufficiently tight in spite of the thing having rotated into an inconvenient position to reach the screw. No problem…pulled the plenum and will make sure it is tight once the engine is warm, because this didn’t really fix that leak. It’s tiny, and there are other tiny leaks around every place where a hose clamp is trying to seal a hard plastic piece to something…like the accordion pieces that attach the plenum to the filter boxes.
The other thing I noticed was that there was smoke coming out of the PCV, basically out one of the little rectangular holes on the clip around the perimeter of the PCV. I’d replaced that 4 years/20,000 miles ago when I did the coolant lines.
Is it “normal” for there to be some leakage there at the PCV?
greiswig
SW Washington
Man, I wish the export feature on the GAP tool worked better. I recorded a fairly lengthy run with a few hard accelerations, monitoring RPM and the fuel trims. Best I can show is the highlights as screen shots.
These first two look "OK" to me, I think. You can see the ramp up in RPM as I put my foot in it, and then there's some adjustment as I basically let off the gas.
Then, however, I get this one, where the post-acceleration spike is pretty high on both banks 1&2. And yet the two banks seem to be largely tracking one another (NOTE the slight variations in scales at left...another issue I have with the software)
So I don't know if this is normal or not, and I likely won't know whether the P0170 code will return until I take my next long trip.
I’m not 100% on this, but I think fuel trims are not very valuable readings during acceleration/deceleration, only cruising and idle. I believe the car goes into open loop fuel control, so not sure if you can discern anything from the fuel trim readings.
greiswig
SW Washington
OK, thank you. Do you have any suggestions for what I should look at to gauge whither cometh this "P0170-00 (27) Fuel trim (bank 1)" that keeps getting triggered? It doesn't seem to affect performance, but it sure doesn't give a guy warm fuzzy feelings to see the engine light come on on the dash.
I still think the misfire was probably triggering the fuel trim code. I’m hoping your fix for the misfire also stops this code from popping up.
greiswig
SW Washington
I hope, but I doubt it; the fuel trim code has been happening on long trips long before the misfire started.
Nobody knows whether it’s normal for some smoke to escape from the PCV when the intake is pressurized to 1psi?
missed the smoke escaping from PCV. no, i don’t believe that’s normal. The way that valve works, it should be sealed along its perimeter by the pressure of the cap. If you’ve got smoke getting out under a pressurized smoke test, either the cap is not down tight or, more likely, the edge of the PCV diaphragm got a bit out of place when it was installed, or maybe not a good fit (not OEM?) though I looked hard at one of the knockoffs right next to the OEM and couldn’t much of difference myself.
