LR4 Air Suspension Fault - Inflating too fast?
JangoSW
Chicago
Took my LR4 in bc of a suspension fault alert. (I couldn't get a fault to readout on my devices.)
My usual mechanic said the code on his device said the suspension air was coming in too fast, meaning there might be dirt keep the inlet open, etc.
I've not experienced any change in the suspension. Goes up and down no problem. No noises etc. This motor was replace five years ago when a AAA guy damaged it changing a tire.
He wanted to replace the Suspension Control Module for $830, but it wasn't a guarantee it would work. Not feeling like a ***** that day, i told him to wait.
Any ideas?
Thanks
S
JangoSW
Chicago
Sorry, just getting around to it. The code is C1A18. The fault warning pops up intermitently. No problems with the car's suspension performance so far.
Do I need to replace the rvh000095?
Thanks
S
JangoSW
Chicago
JangoSW
Chicago
I replaced the compressor, but I'm sill getting the same faults, periodically. Do I need to replace the suspension valve next? Thanks for the help!
rvh000095
Rover Range
Texas
If your old compressor was a Hitachi. The chassis control module will have to be reconfigured for the new compressor.
JangoSW
Chicago
I'm not sure what I have now. The OEM one was broken by a AAA guy, then my shop put in this Arnott, and finally I switched out with a random chinese one.
Longtrail
Ann Arbor
With the gap tool you can see what the RLM module is flashed with (Hitachi or AMK), I suggest trying the alternative from it's current setting. I had a different issue but applying the correct firmware fixed all my issues; here's the thread where I document my journey:
