Auxillary Fuel Tank
scapistron
Massachusetts
This is going to be a long one, strap in.
I ordered the Long Range America tank for my LR4 back in mid-January, delivery didn't happen until mid-June because of current events. It sat in my basement for a couple of months while I tended to other things, but I finally got around to installing it this weekend in anticipation of a long road trip west in a few weeks.
Installation wasn't easy nor exceptionally difficult. It took me about 10 hours overall over the span of three days and only two trips out to the store for additional parts. The quality of the tank seems really good; the rest of the kit seems like it was cobbled together in someone's garage. I'd have preferred to have paid a bit more and had AN fittings or o-ring face seal. NPT is just a bit of a pain in this sort of application where the clocking of the fitting is important. I didn't have any real trouble, but I could easily see someone else struggle with an elbow pointed in the wrong direction. Some of the hardware should probably be swapped out for flanged nuts and blue loc-tite, easier to deal with than separate nuts and washers. The tank could a be a gallon smaller, it is a tight fit.
Installation instructions were below average in my mind. The biggest flaw is right in the beginning when you're instructed to cut he metal filler neck. This is entirely unnecessary and makes the installation irreversible. Don't cut your filler neck, just cut the first hose clamp off and remove the filler neck as one piece. Broadly speaking pre-assemble more pieces prior to putting the tank in than is outlined in the instructions. Attach one of the filler neck unions to the tank, attach the fuel line to the tank, attach the fuel line outlet to the pump. Stuff like that. With skinny arms you can get in there and do it after the fact, but it is a lot harder.
Wiring instructions were just a simple diagram, the rest of it you have to figure out on your own. I chose to put the fuel level indicator and switch on the panel by my right knee and run all of the wiring through the center console and under the carpeting all the way to the spare tire winch access hatch. I stole power from one of the cigarette lighters and left the 5 amp fuse near the transmission emergency release. In some areas I used some 1/4" vinyl tubing as conduit to further protect the wires. For gound I drilled and tapped an m6 hole in the frame. A rivnut would also be a good option here.
I'm not a fan of the path the fuel line takes from the tank to the pump. It completes a full S turn going straight out the top of the tank and down and back up to enter the bottom of the fuel pump. That bottom turn has to be kept tight to keep the fuel line as far from the exhaust as possible. A "u" shaped piece of stainless tubing would be nice here. I can't see another way to mount the pump that would be acceptable. While not a problem with the kit, refitting that fuel door assembly was challenging.
I tested it with a couple gallons of gas and everything seemed to work okay so I went to the gas station to fill up. On the drive over I got a loose filler cap warning. I cleared it with the GAP tool, but it persisted. On the drive home I transfered about 8 gallons to the main tank. I placed a latex glove over the filler and refit the cap. When I went out later the error was gone. I'll eventually find out if it was the glove over the neck or that the system now had a good amount of fuel in it so there was less volume to pull a vacuum on.
The small gas tank combined with the poor fuel economy really is a bit of an Achilles heel on these. Being able to go well over 500 miles between gas stops is going to be really nice.
If you do this yourself my recommendation would be to order the following parts.
McMaster 90427A140 M10x1.25 flanged nylock nuts
McMaster 9895K13 Solder-loaded heat shrink butt splices
McMaster 9983K15 Solder - crimp ring terminal
Additional 5/16 fuel line (4 feet)
Additional 5/8" fiber reinforced vinyl tubing (1 foot)
Assortment of appropriatly sized stainless hose clamps
wire brushes and rust converting paint
At some point I'll add some pictures.
scapistron
Massachusetts
powershift
Nevada
I like your posting and information, @scapistron .
However, that looks like a very precarious location for a fuel tank, to me.
Yeah, don't be in off-road height and turn off sand mode into normal mode and expect everything to be fine lol. A big skid plate would suffice, plenty of room and backing to mount one properly.
scapistron
Massachusetts
It doesn't mess with the overall departure angle, but it will require being mindful of high spots when starting any incline. Should be fine for light off-roading.
powershift
Nevada
I'm sure it will be fine if you are careful, I was referring to a previous experience I had https://www.landroverworld.org/thre...egrets-in-daily-life.45886/page-5#post-254278 where I was driving in sand mode and off-road ride height, turned off sand mode to normal, waited, everything was good (mode changed, off-road height engaged) then later bottomed out and it stopped the truck.
Its hard to notice when the suspension adjusts and I didn't realize it was in normal mode. There was no ride height message change either, such as if you are in access mode on the freeway, it will tell me it went into normal ride height or from off-road height to normal invokes a message too. In the pic the spare tire dug into the ground and the impact also loosened the wheel and needed cranks to be secured again. Not sure if the winch is broken now but I should probably be checking that lol.
scapistron
Massachusetts
Short Term Review
So I've done 2500 miles from Massachusetts to Utah with the auxiliary tank and I have to say it is pretty darn good. When you're getting 16mpg, being able to go over 600 miles between stations is wonderful.
My only complaint is that it seems like the name plate capacity is either overstated or the filler neck geometry isn't great. Largest fill was a bit over 40 gallons and the low fuel warning came on as I was pulling up to the pump. I think under those conditions I should have been closer to 45.
I would have expected that tank to be larger because I have one for the LR3, though maybe it is the other similarly named brand. There was Long Range and Long Ranger LOL. My LR3 can take on 52 US gallons from damn near emtpy. ( I did come up short by a mile one time when I was pushing my luck to get to the E-free station LOL)
I've gotten close to 900 miles but don't try my luck too often.
I am not the slightest worried about the tank durability...
q5sys
MD
These are really cool, but man these are pricey for what it is, but I guess that's the normal for low volume production items.
powershift
Nevada
Dig those tires. I'm still on street tires that I bought it with and after hydroplaning on the freeway the other day in the last storm with people passing quite fast while I drove under the speed limit lol. It was out in the country on a mountain pass near the CO river valley. The steering wheel felt super loose with massive sway and delayed response, I had little control but offroad in mud and sand its fine.
In that same storm I went to an offroad park where it was flooding. Didn't feel loose at all driving through the flash floods in sand through river bottoms and it didn't have any traction problems. Probably speed related. The tread pattern in the last pick isn't on the bfg website but is that the last gen MT? I was thinking about skipping the AT and going right to MT's if I can get compmotives 18" next year.
