Fuel pump issues
B Bogart
What is the voltage requirements for the Fuel pump. I measure 5VDC at the three wire connector to the pump when the Ignition is turned on. (Pump NOT Connected). I hear the fuel pump relay energise but not sure if it works. I'm working without Schematics. Truck wont start - no fuel at schreader valve.
joey
Welcome to the forum...
What year and model Land Rover are you having issues with?
B Bogart
Joey
Land rover Discovery I 1997, Vin # ends with VA724060. Its the Fuel pump with two commectors. 3 pin and a 4 pin which i belive is the sending unit, Land rover says its the
more expensive unit $750. I want to br sure before i order one. Tkanks
BB
joey
First don't order from the dealer.... Order from either Nathan listed in my signature, or call Atlantic British, or Rovers North.
Second. IIRC (If I Recall Correctly) it should be 6 volts to the pump.
Third. Depending on mileage it may be a bad pump, but bench test it first before you spend the money... you can rebuild it if the plastic is not all cracked... I know I replaced mine and the plastic was all cracked and in bad shape or I would have rebuild as a spare.
B Bogart
The truck has 165K Miles. Found pump at British Atlantic for 1/2 price (After Market)
Thanks for the help.
bb
BCNJ
