shaking 2001 disco
greg409
I purchased a front shaft from Atlantic British and installed, cost was 399. thanks for all your help
Nice, did you grease it 'til the grease oozed out all four caps on ea u-joint?
(recommended)
If your a clean freak then just wipe off the excess.
happy new driveshaft
luck,greg
jtbpa1
(recommended)
luck,greg
Greases the hell out of it, may be I'll make it another 100k, thanks again
tellie
I have a 1996 land rover dico I took it in to get looked at and had no problems going in. The shop said my power siring was leaking so they put a knew hose on it? I never had leaks until they did this and now its making noise when I turn for the first 2min of driving. well it got worse so I took it in and now the drive shaft is broke could this have been from what they did?
jtbpa1
drive shaft
its doubtful that the powersteering leak had anything to do with the drive shaft. The shaft initially gets sweeky and then shakes the whole truck upon exceleration. I just replaced the drive shaft on my disco, you can find them rebuilt, or just replace the u joints. Some of the other guys on here can tell you how to go about that much better than i. Good luck
1999 disco
2001 disco
tellie
So the car was never shaking I just had a very hard time turning the car to the left do you think it is still the drive shaft I do not to much highway driving so the most speed I get is about 60mph.
1999 disco
2001 disco
jtbpa1
What was the reason you brought it in to have it check out?? If it was not leaking or shaking or doing anthing else, it hard to determine what the problem was. If it was difficultty turning, it could be a the power steering, or a bad wheel. hub. In this thread you will find greg409, ask him as he has a greater knowledge of the disco than I do. Best of Luck
1999 Disco
2001 Disco
