What jack do you recommend to store in your trunk?
hang729
New York
Hi friends
I have an oem scissor jack stored in my trunk but never had a chance to use it yet (touch wood)
With a 2” lift, I don’t know if it is able to lift the truck up when needing to change a spare tire.
Interested to hear what you guys keep in your trunk.
Thanks
ftillier
Portland, OR, USA
lift rods don't affect maximum droop, the shocks do when they're fully extended, so unless you install a SYA kit the factory jack should reach fine. Some people use a small bottle jack, there's a dimple in the lower control arms that you can use to lift just one wheel.
avslash
The Lone Star State
Bottle jack for changing a single tire. Hi-Lift so I can get two wheels offs the ground if needed, but I have the T4x4 sliders that have a nice convenient rail to use a jacking point that spans the entire length between the wheel wells.
Sid1577
