Help in identifying part - Timing Chain Service
weezer
@rover range can't thank you enough for the help. I pulled the part out and confirmed it is the oil restrictor that I shared in the ebay link. It's on order! Panic level now returning to a more even and stable level.
Land Rover Joe
Oxford
Dear @weezer – thanks for posting and creating a very helpful thread!
Dear @Rover Range – always helpful and thanks for assisting the tribe with your knowledge and experience!
The photograph is what I found on the back of the cylinder heads (look familiar!?!) ….so seems like I will now be ordering some (more) items from Parts Geek soonest.
However, I am curious about the 2011 Service Bulletin mentioned by @Rover Range in another related thread about this part # LR011688 -
https://www.landroverworld.org/threads/oil-anti-drain-valve-in-top-of-engine-block-5-0-lr4.45134/
Is there a reason for this Bulletin? I want to replace this part because it is an oil restrictor (and I would like to free up as much oil as possible) as well as it is this tiny plastic part pretty deep in the engine (and certainly don’t want it to break!) Nothing has broken (yet) but I think prudent to be safe rather than sorry.
Your insights are most welcome!
Land Rover Joe
Oxford
Thanks @weezer!
Most excellent!
I just ordered three (an extra just in case...!) from Parts Geek. I had good luck with PG on a previous order, they have them in stock, so am going with PG again and will see what happens.
Meanwhile, the cylinder heads went back on today and got torqued to spec (photo below after wrapping up this afternoon including a friend underneath putting in new O2 sensors after finishing the exhaust headers reinstall).
So we will now have to wait for all the last minute parts I had not expected (these silly Oil Restrictors, two new High Pressure Fuel Pumps (why not?), another new (OEM this time) Water Pump...). We will therefore instead start working on suspension and brakes.
Now transitioning to the brake rebuild after fitting new control arms & hardware, links, bushings, and hubs+bearings to include some snazzy gloss black paint to spruce things up...
weezer
Wow, that looks like an incredibly intense project yet highly satisfying in the end. Best of luck. FYI, my experience removing the old oil restrictors was simple enough. However, inserting the new oil restrictors caused me some anxiety as they were tough to push in. On the first one I though I might break it or better yet get it stuck (permanently). I ended up dipping each in motor oil, aligning the bolt holes as best as possible then firmly pushed straight until it popped in (I applied some serious force... what I would normally consider to be too much). I do believe this added friction is caused by the new tolerances but I'm a DIY'er so please take everything I share with a gain of "double checking". ;)
Land Rover Joe
Oxford
Thanks @weezer!
And excellent point. Here is where we are right now -
So, we have put the cylinder heads back on and here is where that pesky oil restrictor is located (the plastic piece). Since these fits behind the camshaft variators on the FRONT of the cylinder heads (I think I accidentally said on the back side of the engine previously), we will have to wait until the new plastic pieces arrive before we can proceed with finishing the timing (this photograph shows the old restrictor which is just placed for testing/fitting; we will replace it with the new ones once they arrive).
Regarding the other plastic valve (on the back of the engine) – we just cleaned everything up and reused it. If I could easily get my hands on one, I would have replaced it but alas…not this time (now I know!). These plastic parts.......
I have a photograph of the other side which doesn't have the plastic part installed yet.
Once we get this resolved, we will be ready to proceed with the rest of the engine rebuild....
Thanks again!
Land Rover Joe
Oxford
Tribe,
Update for mid-May: New oil restrictors back in. Setting timing under weigh.
No issues putting the new plastic bits in (once they arrived) back in and bolting up. Everything went smoothly and like the 10 Nm suggests - finger tight.
Old ones just seem to be brittle and then snap / crackle / pop.
Shown in the first picture is the old one next to the new one installed in the head.
Thanks for everyone's help and a number of silly plastic parts here which need replacing on these episodic maintenance programs which I had no idea that they even existed....
Hope that helps!
tragic1
