02 RR Wind Noise Problem - Advise Pls!
A
anishdoshi
Recently bought a used 02 RR and have had a problem with wind noise above 70mph from the start. Dealer says theyve done the best they can do, but compared to other RR's, the noise seems to be quite a bit more than normal.
Anyone experienced similar problems or has advice on what to do?
Any add on's? Roof Rack, brushguards, etc.
B
BrettSanDiego
Put tape over all the door seams and window and windshield seals and go for a drive. See if the sound goes away. If so, take one seam off at a time until the sound returns. If it doesn't go away, then you've wasted time and tape. :)
Brett
R
RovnP38
This problem usually winds up being either the top or bottom window finishers.
It could also be the exterior plastic pillar pieces if the seal on the inside has broken down and is allowing air behind it.
But typically some of those clips break on the window finishers and don't allow it to seal against the windscreen properly.. So air gets in there and cause horrible noises etc....
STQAddie91
