2011 lr4 cliking noises coming through speakers
ugmw177
Charlotte NC
my lr4 just started haveing clickcing noises through the speakers even with the infotainment system powerred off. any suggestions?
MellonRover
Northeast USA
Yeah, I did and problem solved. Have a charger port that shows voltage, best $4 spent on this thing so far. I can monitor voltage real time
greiswig
SW Washington
If the sound varies in frequency with engine RPM variation, the alternator is a good suspect. Otherwise…a capacitor in the amp module? IDK
ugmw177
Charlotte NC
thanks, sound does not vary with rpms. I found last night that it seemed the positive battery cable was not very tight. son had to have battery replaced a couple of weeks ago. I re-tightened it and started car..no clicking noises but have not driven it yet. we shall see.
MellonRover
Northeast USA
I bet you found your culprit.
Alternator was probably freaking out a bit because of the loose connection. The alternator varies output based on what voltage it sees.
