That is a little quick but not crazy. Snap a pic of the pads installed. Was it a shop that told you they needed replacing? They could be crooked. Yes you can reuse the rotors if they are not worn beyond service limit.
Where would you order brakes from? I can’t see to find it under $550ish range. With $60-70 shipping it would only save me $100 or so from my indie shop. They’re only asking for $740 for front discs/pads/cable and they warranty it against squeaks (which I’ve had issues with).
I’m pretty scared of non-OEM. Do they stop as well? These tanks are big and the good brakes have literally saved my life before (tractor trailer flipped on the interstate and I laid into the brakes)
There has been a lot of discussion about brake pads+rotors in the past. Search the forum and read the old threads. The OEM Ferodo pads are not expensive; EBC are not cheap. Do your homework before switching to ceramics.
Rotors/discs only need replacement if worn below service limit, or damaged. Measure the thickness!! Usually you can wear out multiple sets of pads before needing to replace rotors.
If rotors really are worn out and need replacement: Beware of off-brand or unusually inexpensive rotors. You're not going to get quality discs for $25 each. Zimmerman appears to still be made in Germany, EBC may still be made in UK. OE costs double. Anything else, you know where it's made. FCP has Zimms for ~$70 front, ~$55 rear, with lifetime warranty (!), free shipping. They don't carry Ferodo pads, but RMEuropean does.
You're not going to get quality stuff for much under $400 total if shopping for front+rear complete kits. But it is unusual to need front + rear at the same time. If not changing pad compounds, front can be done separately from rear. Oh, and don't get old rotors "turned"... if they need it, replace them instead.
