2016 low brake fluid warning after long non-use
Frank8
Vermont
Started truck this afternoon after it had been parked in my garage for 3 weeks. Red “low brake fluid” came on. Brakes worked perfectly last time I used it. No fluid on garage floor under car. 51k miles. I’m 85 and have become ill so won’t be driving and was just going to take car to be detailed prior to selling. No indie near me, but a shop about 3 miles away would look at it. I have no idea why light would come on without fluid leak.
Do you guys think it’s okay to take on road and drive it to the shop? I drove it around my driveway without problem. Or is there something sneaky that I’m missing?
Frank8
Vermont
According to the manual I need to remove the engine cover on the driver side. I looked and afraid I’m not agile or strong enough to do that.
It’s puzzling because the car spent 3 weeks in the garage and there’s not a drop of anything on the concrete.
powershift
Nevada
If you can't check the fluid then its better to tow it. The plastic latches on my brake fluid cover was cracked like someone tweaked it removing it. There are tabs to lock the lid down, try a standard screw driver it shouldn't be heavy. Only one latch on mine works.
Frank8
Vermont
Thanks!it came off easily-I don’t think it was snapped entirely shut.
But yikes! The reservoir looks completely empty.
powershift
Nevada
If it was completely empty, air could have entered the lines and that is a dangerous situation. If there was just a tiny bit left then you should be good to just refill. Otherwise, the brake system will need to be bled of air before driving it.
ugmw177
Charlotte NC
my expectation is that your brake lines are rusted especially if you live in a road salt area. the main lines running near the parking brake module like to rust on these vehicles and will lose a little fluid there over time but not enough to drip on driveway..they will eventually fail completely. It is an expensive job to replace them but absolutely necessary if found to be rusted. I would tow to shop and have them inspect the lines.
Frank8
Vermont
Thank you all for your advice. I’ll arrange to have it towed.
I guess my old pal is packing it in.
davidsussex
