DiscoveryInTheSun
I'm having a ( seemingly ) intermittent issue with the front driver side door not unlocking with the key fob. When pressing unlock on the fob, all other doors will unlock apart from the front driver side door. The only way to get it open is to enter through the front passenger side door and open the front driver side door using the handle on the inside. After doing this, you can close that door, lock it using the fob ( which locks all the doors including the front driver side ), then unlock it using the fob and all doors ( including the front driver side door ) will unlock. It will do this ONCE, and then revert back to the behavior where all doors unlock but not the front driver side door.
I've disabled the keyless entry just in case it was something to do with that, but it seems to make no difference. I also can't tell if the intermittent nature of this has anything to do with proximity to the car when the unlock button is pressed on the fob.
One other potentially interesting observation - the front driver side door also will NOT unlock using the physical key, the lock doesn't move at all when you try to turn the key.
Any ideas on this one until I can get it to a dealership?
Thanks in advance!
Thanks in advance!
