99 disco right SLS stuck way up help
C
chuck21401
I installed the new sensor. Lifted the back end up and let it back down a couple of times. The right side (where the new sensor was installed) is now a bit higher than the left side. Is there any adjustment here? How does one make the self-level suspension level (from side to side) again? Yikes.
D
discomike
You might want to lower both sides all the way down which would require all the pressure be bled off. Easiest way to do that is crawl under the truck on the drivers side to the control unit, take the cover off and loosen both lines, don't remove them just loosen enough to allow the air to escape. When down flat, tighten the lines and start up the truck, see where it settles then. If that doesn't work you have 2 choices, atke it to the dealer and have it recalibrated or put those adjuster on and adjust fro there.
Mike J.
C
chuck21401
I'll try the first idea today. I also want to look at how the sensor is bolted to the body, maybe there is some play in there, I'm not sure.
I was also thinking about swapping the sensors from left to right and right to left to see if the left side would be higher. I think that would tell me if the issue is with the sensor, or somewhere else in the system.
C
chuck21401
I adjusted both sensors. Each sensor is bolted to the body with two bolts. There is some play in the way the sensors are bolted to the body which impacts the sensor reading.
STQAddie91
