AC Drain diagram.
motz
Does anyone have AC drain diagram, from the footwell on the driver side to where it spills out? Because I found something odd. I get wet floorboard
so I poured water into the AC drain and it mainly came out from the AC drain hole but before it started doing that, it leaked little bit from two other spots. Is this normal? I am trying to see if there is a leak
remember5
Hard to tell from the pics what that is. There are tons of posts on all the LR forums about water egress into the cabin. 90% of the time the drains are deteriorated and need to be replaced.
  • Description and Operation.pdf
motz
Yes, I checked sunroof drain and it was fine. Tested the AC drain and leaked a bit so I am trying to find where the leak is. It’s not leaking from the rubber connection by the footwell. It leaks after that. So I wanted to see the diagram where it goes after the footwell.
remember5
My apology, you said AC to begin with, I wasn't paying attention. I've looked through and can't find any info on AC drains, attached are the AC and Ventilation overview sections that may help visualize the under side of the dash but nothing really clear about the drains.
motz
Thank you for looking into it though!
Vintage99
