AC Repair
tommy33
97 Discovery SE7
135000 miles
AC blows hot about 2-3 weeks after full recharge. I know there could be a thousnad reasons why but are ther any usual suspects on a Disco when this happens? Evaporator? Connections? Compressor?
Thanks!
If you have rear A/C I will bet on the elbow above the left rear tire is leaking.
Before you go chasing down possible leaks, find a shop with a sniffer or you will be waisting your time. Some have used dye, the problem is, if you can't see a part, like inside the dash, you won't know it is leaking.
PE_in_UAE
