Adding Recovery Points to a Disco II & Bumpers
I'm sure there are a million different combinations, but here is what I'm looking to do.
For now, I would like to keep the stock bumpers. In the front, I'll probably be adding a DAP hidden winch mount for the winch. :cool: Longer term, I'll probably be going with 1-2" of lift.
How do I add recovery points front and rear with that in mind? I have the factory tow bar installed in the rear.
Any installation ideas, recommended vendors, etc. would be helpful.
Thanks!
NGOphotographer
A little thought, if you add the winch prior to lifting the suspension, the front end will be nose heavy.
I would suggest you do the lift first, don't use one of those hidden winch mounts which just leave you open to being hit from the front and under neith all the time. Consider going for a bumper, then a winch, you will have a much better set up.
As for recovery points, there is no place on stock bumpers to add them.
Some people will install Jate rings to the frame, but them you have to cut a slot in the bumper to run a cable or strap thru.
MrRodgers
