Aftermarket Sound System???
S
schafari
I see that you used the Optima battery, which I love. However, I thought that the LR3 used some sort of weird calcium or sodium something or other battery. I thought I read somewhere that it was not the normal lead acid battery that LR uses in the LR3.
Have you heard of this, or have you had any alternator/battery problems?
jager24
The Optima is only for the 2nd battery separated by the isolator( Surepower 1314). It runs the fridge and stereo amps only. The stock Land Rover Battery is still there. No problems so far. The dealer here in Scottsdale checked it out and found nothing that would cause problems.
stan7b
I am curious as to the bezel around the head unit. What paint did they use to match the stock interior? It looks almost dead on.
-Stan
jager24
Hi Stan,
I don't know the name of the paint but I'll try to find out. Any custom installer should be able to computer color match the trim. The color actually looks better than the pictures show. The flash of the camera shows the difference in texture but you can't see it normally.
stan7b
Thanks for all your help. I will be doing the install my self due to a tight budget and being able to trust an installer in my area. I will get the right components and take my time doing the install.
