Air Susp and DSC Inactive warning lights on '03 RR
C
csevers
The ignition on my 2003 RR HSE locked-up and I couldn't start the car. I had it flat-bedded to the dealer who said it was a steering column problem and replaced it. 20 miles later I am getting "Air Suspension Inactive", "DSC Inactive" messages as well as amber "Brake" and "ABS" lights.
PLEASE HELP?!?
ruffinit
wow, i wish i could help! Good luck...keep us posted. It could be something as minor as wires being crossed.
C
csevers
Ended up being a simple problem. Dealer did not reset EDU - electric display unit - properly. Had it back a week and no problems so I hope its fixed.
R
RangeRoverHSE
You have to reinitialize the system. This is done by turning the steering wheel lock-to-lock going to the left then going to the right while the engine is running but you are stationary. Good luck!
R
renaldop
yeah...im getting the air suspension inactive on my RR-HSE as well...i set up an appointment with the dealer...
MArsel
