Another ABS problem...
'00Disco2
I know there are a lot of posts about this but I just have one more question. My Disco 2 ABS, TC,HDC lights were coming on occassionally and resetting after turning off the engine. Now they just stay on anytime the ignition is on. Does this mean anything different or just the usual 10 easy fixes? I think its about time to replace the brakes and if that doesn't do it, the bulbs are going to have to come out. Not having ABS won't hurt my feelings.
Generally this is either an ABS sensor or the ABS modulator.
'00Disco2
Easiest solution to the ABS lights. I pulled the cluster out, removed the curcuit board and put a piece of tape over each of the three holes. Lights are still on but I can't see them. Total process took approx. 15min. I'm fine without it.
tragic1
