Aux Input Solution?
grommet
That's an amplifier for a speaker! The other autotoys product I linked to is closer.
grommet
As I said before, they lie. It's an attenuator. The level is identical through a passive (non-powered) iPod dock with line-out. So even if it was a "real" amplifier, it's not increasing the level beyond any other device I've used.
L
lacarruk1
I swear I hear a distinct increase in volume using it. If I go direct AUX instead of thru car kit, I have to raise radio volume to MAX to hear it at a reasonable volume.
grommet
As I said before, the iPod headphone jack is NOT the line-out on the iPod. Is that was you are comparing? (And what you call "direct AUX"?) Line-out will be closer ("louder") than the headphone jack, but it's still -5 volume ticks off on most/all iPods. And Navigation voice will still be too loud... :(
grommet
Clean: Pull out your AUX assembly and modify/rewire the line driver to be inline to the actual AUX L+R wiring. The whole unit can probably live behind the panel. Power for the line driver can be tapped off the rear of the cigarette power port.
Less Clean: iPod line-out (or equivalent) --> 3.5mm to L+R RCA cable --> Autotoys Adjustable Line Driver (or equivalent) --> L+R RCA cable to 3.5mm plug --> LR3 AUX input. (You'd still need to run 12v DC to the line driver from somewhere.) You can probably hide the bits...
I also found another one: http://logjamelectronics.com/pield1.html
But, like I said, this stuff is untested and you might still have level issues... or even distortion. Talk to a custom shop if you are uncomfortable with any of this.
S
schafari
Check out how I fixed the Aux Input output level in my post in a new thread.
jptruck
I use the Belkin hook-up for my iPod and I swear I can't hear a level difference between the Aux and CD. The Belkin device does up the volume a bit. The lower end range is also MUCH more noticeable. I actually had to lower the bass settings a bit to accommodate. I know there are many more complex solutions that will solve the XM/SIRIUS and iPod issue, but this is by far the simplest and easiest solution for those using iPod only. Plus, there's only one wire coming from the rear seat.
PE_in_UAE
