Cd Changer !
omega0407
Hi !
Avery One !
I Need A Little Help, I Don't Know How To Switch From Radio To Cd Changer In My Disco 97. Could Somebudy Talk Me ? Please.
Thank !!!!!!!
On the right hand side of the steering column, you have a button that has SEL on it... Press this until the read out says CD... Make sure the CD's in the changer are facing the correct way, the should be blank side up.
omega0407
Hi ! Joey
I Did, What You Say, But Nothing
Just Switch To Fm1,fm2 And Am
What Else Do I Can Do?
Are you sure you have a CD player? Check under the passenger seat to make sure there is one there.
omega0407
Yes, I Do.
Already I Put The Cd In
The Cd Changer Read The Cd And Play It, I Can See It In The Cd Changer Control.
So from the above, do you mean that it now works? or it worked in the past?
S
sjskarts
Is it a Landrover cd changer or is it and after market one,does it have a remote?
if so youmight have to tune it to a certain station for it to work. Like 88.3 or 88.7...
omega0407
Thank Sjskarts, You Right. It To Be Tune It To The Station "88.7"
But Sometime It Switch To The Radio And I Can Heir The Station .
It's This Normal Or Do I Need To Do Anything Else?
S
sjskarts
When the cd player is off the station will play whenit is on you shoul hear the cd!
BCNJ
