Check engine light on
AZRoverLR4wm
Overgaard AZ
Just finished a cooling system upgrade, and my car is running fantastic. However, new issue, CHECK ENGINE LIGHT is on. Strange because the car runs flawlessly, accelerates flawlessly, and has absolutely no issues that I can see.
I have removed and cleaned the mass airflow sensors with mass airflow sensor cleaner. I have also added BG44K to my gas tank. Check engine light is still on.
What should I be looking for next?
Attached is a picture of the current faults via the GAP IIDTool. Wouldn’t a check engine issue be shown in current faults? Anywhere else I should be looking On the tool? Otherwise, I don’t think I see anything that would warrant a check engine light.
Any thoughts GREATLY appreciated!
AZRoverLR4wm
Overgaard AZ
I have cleaned the MAF Sensors. Cleared faults with the Gap tool. Re-ran current faults and that is what is shown in the picture. Do I need to do something in addition? Is there a special process to clear a check engine light?
scapistron
Massachusetts
Do you know if you had those codes before you did the cooling system upgrade? I would guess something is not plugged in.
powershift
Nevada
Did you have a mess with coolant spilling onto connectors? I would inspect the connectors.
16RRSportjyn
