Hi all-
After many weeks of looking, and dealing with some less than truthful dealers... We've picked up an 08 HSE Lux that we were looking for.
I picked it up Thurs, and we took it on vacation starting Sunday. So we are having fun on both fronts.
One thing I noticed is that the 12v rear power point is 'switched', ie the power cuts out once the vehicle is turned off. This is a real bummer, as I like to run my Arb fridge for extended periods... The Arb/Engel unit is so efficient that it can run for hours without drawing down the battery significantly.
Alas, I cant really take advantage of that anymore because the rear power point turns off once I remove the keys.
I cycled through the key positions I/II/III, and the rear only seems to have power when the truck is running.
I realize it's a long shot, but is there a simple trick to get constant power back there? Mind you, I'm on vacation... So the option of running a dual battery setup with a dedicated port is not really an option right now...
TIA.
TIA.
There is very little room to maneuver and some wire harnesses get in the way. I actually had to use a pair of needlenose pliers to slide the bridge in place. But the whole job took about 5 minutes, including making the bridge.
