Door Adjustment
Androomantoo
Olathe, KS
I did some searching but didn't find what I was looking for.
The drivers door on my 2012 HSE is "stiff" for lack of a better term. Everything works just fine, but it's almost like there's something pressing against the door keeping tension on it. It opens... stiffly and sorta pops open violently. The other doors all open and close with the trademark LR thud and open smoothly. The drivers door also feels like it hits the striker a split moment before it latches making it feel clunky and not very quality.
Anyone experience anything similar or know how to make adjustments on the door to help with this stiffness and clunky latching? Do I just need to lube or replace the door latch?
The weather stripping on the body in the door opening is worn and needs replacement but looks to be installed in the correct place so I don't think it's that causing the "pressure" on the door.
Thanks!
Rover Range
Texas
The striker -part that is bolted to the body- can be adjusted. It's a T40 torx.
Loosen the two bolts slightly and move the striker. Retighten the bolts. Check the door fit. Keep trying until you're satisfied.
Androomantoo
Olathe, KS
The striker -part that is bolted to the body- can be adjusted. I think it's a T45 torx.
Thanks!
I'll add that to the list of things to do to the Rover this weekend. Hopefully I can get it adjusted and not have the door look misaligned.
txfromwi
Is it the door that's mis-aligned (sagging) or just closing hard?
Closing hard is the striker location or a hinge that needs lubrication.
Mis-Aligned is the hinges that have worn and the door is sagging (like my 2002 Maxima...)
To diagnose a worn hinge, open the door just a bit, pick the door up at the end and try to lift it, if the entire vehicle moves up and down, then the hinge is OK, is there is any clunk or slop and you can move the door up and down without the vehicle moving then it's the hinges.
Androomantoo
Olathe, KS
Hinges seem fine, nice and tight, no sagging that I can tell. I noticed when I am slower and more deliberate with opening/closing the door seems fine. I am going to try lubing the latch and hinges to see if that helps.
LR4 2011
united states
How to adjust door up (drivers door) to align with rear door. Door is down approximately 1/8". I am looking for a short cut with out removing front fender to get to the hinge hardware. Is there a ****** washer between top and bottom portion of hinge?
00Jam
