Hello. I have problem for Land Rover Freelander 2002 v6. It only works with reverse gear. If i remove all gearbox electricity then it works with only 4th gear doesn't matter if i turn it in 1st or 2nd gear still it is moving with 4th gear. when i turn gear to D electricity disappear at Reduction time solenoid in 2-3 seconds. Look up solenoid has very little electricity. Diagnostic shows only P0102, P174 and P177 code. Can you explain what's reason or how do i start searching the problem or whom do i contact for these problems? Sorry for my bad english. Thanks in advance.
